Prop Question >
Prop Question
Prop Question
Old 12-11-2009 | 09:47 AM
Default Prop Question
97 35' single step Fountain Lightning. I have (2) stock 500HP carb and am running bravo 1 26P. What props should be used on this set up for max RPM and Speed??? Would 28P bravo 1 labbed props be best??
TubzzFormula 271 is offline
Old 12-11-2009 | 10:53 AM
racinfever's Avatar
I had the same boat, ran best with 28 Hydros
racinfever is offline
Old 12-11-2009 | 11:12 AM
throttleup's Avatar
Yes sir, semi cleavers are the way to go.
Julie
throttleup is offline
Old 12-11-2009 | 03:17 PM
what are you running now? speed/rpm?
tcuda499 is offline
Old 12-12-2009 | 10:05 AM
Dont have GPS and was kinda leary about opening it up WOT because I just got the boat. But I throttled up and the RPM's were over 5200 and that kinda worried me. Not exactly sure what WOT RPM should be on those motors. That was basically WOT for a few seconds.
Old 12-12-2009 | 01:30 PM
The rev limiter is at 5350-5400rpms. They are fine to run up to 5300rpms on a regular basis. I deally you would want to prop it to run right about 5200 at WOT. You just don't want to be hitting the rev limiter all the time. Keep in mind, the tachs could be off a a little in the upper rpms.
Griff is offline
Old 12-12-2009 | 08:01 PM
H2Xmark's Avatar
i have the same hull and run 28 hydro Q4's labbed by throttle up turning in, gives best top speed , turn out give better docking but slow's you a small bit in top speed
H2Xmark is offline
