7.4 exhaust header fit 502/450hp
Wonderful thanks.
Btw, How good are these 502/450hp marine long block that's available? Can they easily be upgraded to 500hp with some bolt-on mods? I'm making mine carb.
I dont know anything about whatever long blocks that you are talking about. I went long block one time with what I thought would be a good motor and it ended up being a POS. Since then, I dont buy anything rebuilt because you dont know what parts are in the motor...cast or forged. I have also found out that it really doesnt matter what they tell you about the motor...it usually isnt true.
did they by any chance give you a build sheet with the engiine?
if you can, find out what is in it. It should have forged pistions and steel crank. 450hp for a 502 is mild, the question is how did they get there hp rating, you can bolt on some hp with a good exaust sys. and carb & intake, but it would be good if you knew what cam it had.
larry
larry
I have some stock 496 manifolds that I took of my 02 Nordic Heat that I would sell for cheap. I put lighting headers on this winter. Call me well work out a deal
Thanks Brayden 509 220 1378
Ive got a set of fresh, powdercoated GILs w tubes for cheap.
Email if interested...
[email protected]
Kevin
[email protected]
Kevin
