525sc valve Springs >
525sc valve Springs
525sc valve Springs
Old 12-17-2009 | 03:22 PM
Default 525sc valve Springs
I have a pair of Merc 1998 454 cu. in. 525sc motors with 380 hours. What is the normal rebuild time or maybe just replacing the valve springs and rebuilding the superchargers at this time. The motors seem fine with lots of power and no issues. I am thinking of preventive maintence. Looking for some opinions or ideas on upgrades like different cams that would work with these small blowers.
LK 525sc382 is offline
Old 12-17-2009 | 08:20 PM
Here is the reply that I posted when you asked this question in the General Dis. section a few days ago. Maybe you didn't see it.
You are due for a top end. I just did the top end on a 525 sc about 2 months ago. They had right at 300 hours and the springs had lost over 20 psi. That is a substantial amount considering they are only about 140 on the seat. I didn't remove the heads. We did a leakdown and all seemed well so we just did the springs, 10* retainers, 10* locks, and new seals. I did remove the engines to do the work. It's a good thing that we did because we found several other problems (wiring had melted and was touching the exhaust from a previous overheat, water pumps were leaking and caused tons of rust, etc) This also allowed the owner to clean and paint the bilge.
The head gaskets are a really good idea. If you are going to pull the heads, then a valve job is a must.
As for the blower, if you can verify that the oil has been changed every 25 hours, then you are probably OK. If you are not sure about the service intervals, then you should probably have it freshened up. They have a tendancy for bearing failure do to gasoline contaminating the oil in the blower. Gas is a terrible lubricant and the bearings fail because of that. I would recommend Darrin Meyer in MI. It will run around 500-600 per blower for a complete rebuild.
Hope this helps. Give me a call if I can help.
Eddie
Young Performance is offline
Old 12-18-2009 | 09:08 AM
would look into a good aftermarket set of springs....the merc ones which they do not make are STUPID $$$$$$ I can buy 3 sets of PSI's for my top sportsman engine with a 800 lift solid roller for the price of the merc's !!!!
ezstriper is offline
