??? Carburators On 502 >
Old 02-03-2010 | 07:15 PM
Default ??? Carburators On 502
Hopefully an easy question for you knowledgeable motor guys. I have a couple carbs from my original 93' Merc 502's. I looked at the Carbs can't find any info or Manufacturer or part number. Does anyone know what type of carbs these are. I want to list them for sale but want to describe them acurately.
Don't know if Merc would have used more than one type back then.
Thanks in advance for any help.
cocktails is offline
Old 02-03-2010 | 07:19 PM
Default Fixx
they could be holly or webber,, look on the choke horn if it reads a list# then its a holly..
send me a pic and il tell you what they are..
[email protected]
FIXX is offline
Old 02-03-2010 | 07:44 PM
[email protected]
Thanks Mr I will take a pic tomorrow. Someone else told me he thought they might be Rochester's. Did Merc use all 3.
Old 02-03-2010 | 08:19 PM
Carter also.
getrdunn is offline
Old 02-03-2010 | 08:23 PM
Aren't the most common carbs on these motors the 750 cfm Rochester Quadrajet carb?
wjb21ndtown is offline
Old 02-03-2010 | 08:33 PM
I remember my old boat 93 Challenger with twin 454's came with Carter I am pretty sure. It was years ago and I didn't have them on long so am not 100% sure however I know they were not Q-jets.
getrdunn is offline
Old 02-03-2010 | 09:12 PM
Default fixx
if they were rochester the secondarys would be 2 1/2 x the size of the primaries throttle blades...Weber,carter,edelbrock are all the same castings by weber and you would see Weber's name casted into it..holley would have 2 fuel inlets on the choke side of the carburetors,weber and q-jet would have one fuel inlet..
FIXX is offline
Old 02-03-2010 | 09:23 PM
if it if hp500,its a holler,im not sure about the rest of the carbed 502s.
mike tkach is offline
Old 02-03-2010 | 09:25 PM
oops,did i say holler,OK HOLLEY
Old 02-03-2010 | 10:04 PM
correct.
getrdunn is offline
