Power steering leak?? >
Old 04-17-2002 | 02:47 PM
Default Power steering leak??
I am using up power steering fluid and can not find where it is going???? It is not in the bilge or in the water that I can tell. Any help is welcomed.
Brian
tmthunder is offline
Old 04-17-2002 | 03:04 PM
ToddW's Avatar
Maybe a leak in the power steering cooler ???
ToddW is offline
Old 04-17-2002 | 03:07 PM
imq707s
How much are you loosing? Did you do any work to the system prior to the fluid disapearing? The system might have bled some air out of the lines, that may have dropped the fluid level some.
Old 04-17-2002 | 06:07 PM
I have not done any work to the system. It is losing almost all of the fluid every 2 days of running so it is a pretty big leak. If the cooler was leaking wouldn't the fluid be coming out of the cooling water discharge? There is nothing in the water I made sure of that. How could I test the cooler?
Regards,
Brian
Old 04-17-2002 | 06:13 PM
ToddW's Avatar
When you are looking for the leak, is the steering turn all the way one way to dead head the pump for max pressure?
ToddW is offline
Old 04-17-2002 | 06:21 PM
No it was not at the max. That is a good idea didn't think of that.
shaun8747
08-20-2007 07:42 AM
Phantom1
0
07-18-2005 08:08 AM
BlownBajaOnHavasu
6
05-02-2004 11:14 PM
mg503
0
05-26-2003 10:26 PM
Out There
7
04-04-2002 11:47 PM
