HP 500 Cam and Blue Carb Specs?? >
Old 02-11-2010 | 03:30 PM
Default HP 500 Cam and Blue Carb Specs??
Standard HP500 Blue Carb, what are the Jets, Power Valves etc. I am removing my supercharger and building the block back to HP 500 specs.
Any suggestion on Cam? What were the cam specs on the HP500's?
I would like to get as close to HP500 spec as possible with the cam so I can just use the Merc recommended jetting. Perhaps someone else has a cam a jetting spec that is tried and true?
BadDog is offline
Old 02-11-2010 | 04:51 PM
rmbuilder's Avatar
MarineKinetics
BadDog,
Here is our card on that cam.
rmbuilder is offline
Old 02-11-2010 | 06:37 PM
Bob, Thanks for the info. I contacted you last week via phone and my engine builder should be in touch soon.
BadDog is offline
Old 02-12-2010 | 12:01 AM
Holley 800cfm HP500 stock jetting is:
Primary - Port 81, Stbd 75
Secondary - Port 89, Stbd 93
6.5 PV in the front. The secondaries don't have a PV.
If I was rejetting, I would probably just use 77 primary jets and 91 secondary jets.
Griff is offline
Old 02-24-2010 | 09:44 PM
formula377's Avatar
griff is that standard?
whats the reason for different jetting for each side?
formula377 is offline
