'93 Merc 2.5 - timing question >
Old 04-18-2002 | 09:09 AM
Question '93 Merc 2.5 - timing question
Fellas, How much total advance should I be running on my 1993 Merc 2.5L ? Oh, and where the h*ll is the timing pointer, or do you have to make your own?
Thanks in advance,
Nate
ASD-6 is offline
Old 04-18-2002 | 08:03 PM
FYI 22 deg. fully advanced.
ASD-6 is offline
Old 04-19-2002 | 01:10 AM
MERCMAN
TIMING MARKER IS ON THE FLYWHEEL COVER , YOU NEED TO RECHECK TOP DEAD CENTER BEFORE YOU TIME IT.
Old 05-27-2002 | 11:28 PM
mcollinstn's Avatar
Make a TDC checker out of an old sparkplug.
Auger out the center and tap it for a machine bolt. Run the screw in until it hits the #1 piston about a half inch before it gets to the factory mark. Bump the piston into the stop (by hand of course) and mark it with a scratch on a gear tooth. Turn the motor backwards until the piston hits from the other direction. Make a scratch. The true TDC is exactly halfway between the marks. Adjust your factory pointer (or your own pointer) to that spot.
mcollinstn is offline
tssteph
2
07-24-2008 07:49 AM
tomcei
11
09-13-2007 10:57 AM
dagah2x
9
06-16-2006 12:37 PM
THEJOKER
01-22-2003 12:58 PM
Scott
4
07-23-2002 08:23 AM
