Stereo install question >
Old 02-28-2010 | 03:04 PM
xhere's Avatar
Default Stereo install question
Installing 3 pair of 6.5 polk DB component speakers and 2 polk 12 inch subs in sealed boxes with Alpine head unit. I just purchased the boat and stereo system was stolen, so I have to fill the existing holes! Any recommendations on Amps? Im trying to balance sound and low power usage. The system will be ran off 2 dedicated batteries. Can this be done effectively with one amp? Thanks in advance!
xhere is offline
Old 02-28-2010 | 03:22 PM
BDiggity's Avatar
Alpine pdx's. small, efficient, powerful & relatively cheap on ebay. It would be hard to run all that off one amp. The pdx's put out same power whether its 2 or 4 ohm load. You can probably do a 4.100 or 4.150 for the comps, have 2 pair wired in parallel on two of the channels, & the other pair on the other two channels. You would then have that channel available if you decide to add another pair. You could probably then use a 1.600 or 1.1000 for the two subs; depending on the subs ohms.
I have my pdx's wired for normal 4 ohm load. takes more amps but running 2 ohms pushes your equipment a little harder.
BDiggity is offline
Old 02-28-2010 | 04:33 PM
xhere's Avatar
Below are the specs on the speakers:
#2 db12440 Polk 12" subs RMS 50-360/4ohm
#3 sets db6501 Polk 6.5" component RMS 10-100/4 ohms
I thought it might be tough running 1 amp, but I want sure. I will check out the PDX amps, thanks...
xhere is offline
Old 02-28-2010 | 09:32 PM
xhere's Avatar
I just purchased the Alpine 4.150 and 1.600 hope they work good!
xhere is offline
Old 02-28-2010 | 10:34 PM
They work very well. You will not be disappointed.
Griff is offline
