Stereo Question >
Stereo Question
Stereo Question
Old 03-09-2010 | 04:14 PM
Default Stereo Question
Hey everyone,
I'm hoping you can give my some insight on my stereo issue. Last summer I bought a 2003 33 OL and the previous owner put two subs and replace the amp in it. It looks like he ran this through the circuit breaker on an accessory breaker down in the cabin. It works/sounds good, but when I'm playing the stereo loud and when there is a song with a lot of bass it trips the breaker. My question would it be best to completely bypass this and put an inline fuse there or just put a bigger breaker in? I would think i could get better sounds quality if I completely bypassed it but I don't know.
Any info would be greatly appreciated.
hoff2483 is offline
Old 03-09-2010 | 04:42 PM
Originally Posted by hoff2483
Hey everyone,
I believe my factory Clarion amps were hooked up that way from the factory. It sounds like the previous owner might have just used the old wiring but the new amp pulls more juice now. I replaced the entire system right after I got imy boat. My opinion would be to bypass the circuit breaker and run new power and ground wires from the battery directly to the amp. I would install an inline fuse 12" - 18" away from the battery. Be sure to use the appropriate gauge wire and a fuse rated for that amp.
Busta is offline
Old 03-09-2010 | 05:14 PM
I would go direct to the battery with an inline fuse and keep the amps as close to the battery and subs as possible! The shorter the wires both from the battery and to the sub the better
502ss is offline
Old 03-09-2010 | 09:50 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Direct to battery with a fuse is best. Don't skimp on wire sizing either. Both pos and neg are same size wire.
Do not put in a bigger breaker. That breaker may be sized for the wire it is protecting, (or at least it should be). By going to a larger breaker, it's possible to melt the wire before the larger breaker will trip.
US1 Fountain is offline
Old 03-09-2010 | 11:33 PM
New wiring is a must I would go to your battery switch so you can kill the power to your system. If you go to the battery I would install another circuit breaker right next to the battery just for the system. Without knowing what size of amps you are running I couldn't tell you wire sizes. But if you are running more than one amp I wouldn't run anything smaller than a 4 ga wire power and ground.
stoltz is offline
Old 03-10-2010 | 11:24 AM
If you have anything over a 1000 watt amp i would reccomend 2 gage wire, i personally run 0 gage but thats just personal preference and the thicker the wires the more continuous power running to the amps
85Baja is offline
Old 03-10-2010 | 02:22 PM
Thanks for all of the input guys!!
hoff2483 is offline
