Whipple MOAC IC plumbing >
Old 03-13-2010 | 07:37 PM
Default Whipple MOAC IC plumbing
Has anybody plumbed a whipple MOAC IC from a two stage pump. Whipple recommends -16 from pump to sand stainer then (2) -12 from the strainer to the IC. I don't want to starve the engine with water. Two stage pump has 1 1/4 hose from out drive through strainer the to main inlet of pump.
Advantage 575 is offline
Old 03-13-2010 | 10:13 PM
PAST DUE's Avatar
i dont think you will be able to get enough water through your outdrive to supply the engine and the intercooler i think its best to force feed the intercooler from its own water supply like separate pickups
PAST DUE is offline
Old 03-13-2010 | 11:40 PM
CB-BLR's Avatar
Chris
x2
Chris
CB-BLR is offline
Old 03-14-2010 | 01:47 PM
Originally Posted by CB-BLR
x2
Chris
X3 just get a pick up on the back of the boat for the IC all by itself. This is really the best setup
I DIG IT !! is offline
Old 03-14-2010 | 06:06 PM
Default MOAC IC Plumbing
alright, a pickup for the IC. Then what is the best method for two stages from the pump? I have a 575 SCI plumbing system but the motor is a 540 CI with 871. I want to keep my thermostat and c-pump
