Bravo Outdrive Question >
Old 04-21-2002 | 03:16 PM
CigBoat's Avatar
Default Bravo Outdrive Question
I went to check on the boat this weekend and noticed that the gear lube bottle under the hatch was empty, the seal on the bottom drain screw fell off before I put the plug in and refilled it in the fall. So over the last few months most of the drive oil leaked out. I noticed this before I ran the boat thank god. I refilled it and put a new seal on. Is there any possibillity that I need to do or check anything else before I run the boat for the first time?
Todd
CigBoat is offline
Old 04-21-2002 | 03:28 PM
Tinkerer's Avatar
Cool
As long as you refilled it before you ran it it should be fine. I take my drives off every fall after I drain them and put them in my basement. Hey they have to come off to check the engine alignment and grease the U joints. I do this every year...
Tinkerer is offline
Old 04-21-2002 | 08:19 PM
blue thunder's Avatar
Was the boat in the water? Was there any water in the oil you drained out, before refilling? I would check after first run to see if you don't get an emulsified oil milkshake. Oil should look like new.
BT
blue thunder is offline
Magicfloat
08-06-2007 12:06 PM
DISTURBED1
Mid Atlantic US
2
06-18-2007 01:01 PM
Gerry Hensen
08-28-2006 10:13 AM
260
3
08-06-2006 11:19 AM
outlawinil
04-29-2005 11:01 PM
