Using propane torch to remove trailer tire bolts >
Old 03-22-2010 | 07:29 PM
Default Using propane torch to remove trailer tire bolts
I was thinking about using a propane torch to try and remove one stubborn tire on my trailer. The bolts broke my ratchet, and my extension. The trailer is a 1996 and its really rusted. Has anyone tried and and how successful was it?
272bajadriver is offline
Old 03-22-2010 | 07:47 PM
try soaking wiht PB blaster and letting it sit for a while. if that doesnt work heat will do the trick but you have to get it pretty hot
hotjava66 is offline
Old 03-22-2010 | 08:10 PM
If you want to be cheap about it buy a Map gas container, you'll thank me. Those propane torches are a little better than a cigarette lighter. If you really want to do the trick buy the Map gas torch and container (Still under $60, even for a good one), but even if you don't want to buy a new tip get the Map gas container and use it on your propane tip. It will only cost you about $7 and it will be worth every penny.
wjb21ndtown is offline
Old 03-22-2010 | 08:40 PM
fireboatpilot's Avatar
RIPSTA Racing Team
You need a bigger, longer breaker bar, nt a ratchet. Better yet an impact gun and the PB blasted should work.
fireboatpilot is offline
Old 03-22-2010 | 09:27 PM
I agree with that too... Or a nice pipe that fits over the end of your ratchet.
"Give me a lever and a place to put it and I could move the world"...
Old 03-22-2010 | 10:05 PM
If you use heat to loosen it up, replace the stud and the nut. Hot enough and you'll ruin the heat treat on the bolt.
1/2" breaker bar and an impact quality socket (usually satin black) is a good bet.
bustedbrick is offline
Old 03-23-2010 | 01:31 AM
Don't use a pipe on you ratchet unless its under warranty. Chances are the nut is seized to the wheel as well as the stud. Soak it a few times a day for a couple days with PB Blaster. Then use an impact wrench with at least 300# of torque. If that doesn't work, you will have to use a long breaker bar and will most likely the stud will snap.
Griff is offline
Old 03-23-2010 | 06:06 AM
On the money. We use heat all the time go yellow and ditch the blue. Thank us later.
bwt- Dont worry about getting it to hot. HEAT IS YOUR FRIEND
alexgr8 is offline
Old 03-23-2010 | 06:14 AM
If you do heat it, pull the valve stem. Still be an easier job with te right tools, impact socket breaker bar etc.
phragle is offline
Old 03-23-2010 | 07:16 AM
PatriYacht's Avatar
Sometimes it's easier to just snap the old stud off and then tap in a new one. A breaker bar and a 3 ft. piece of pipe will do it.
PatriYacht is offline
