Fuel Tanks
Old 04-23-2002 | 10:05 PM
Default Fuel Tanks
Have a buddy with a fuel leak. He thought at first it was the hose from the tank, but after removing the hose from the pick up the fuel still appeared in the bilge.
The boat is a 1989 24ft Baja Sport.
Is it common for the tanks to have leaks?? Can the tank be repaired?? If not wear is the best place to buy a replacement??
TomR is offline
Old 04-24-2002 | 10:12 AM
I just changed both of mine out in my Sport Cat. The problem was water would get in the tank compartment and then not drain completely out. The tanks sat on three strips of carpet. The water would wick up into the carpet and eveywhere the carpet was, there was signs of corrosion. One side had holes that went all the way through. I got two new tanks and had them coated with a thin coat of that stuff they spray in pick up bed, "rhino lining". Instead of using carpet for a cushion, I used the stuff they make wet suits out of. Soft yet won't absorb water. Oh yeah, I also opened up the compartment drain hole so the water would run out to the bilge pump. Tanks can be repaired, but in the big scheme of things, new ones aren't that expensive.
Craig
mltdwn12 is offline
Old 04-24-2002 | 10:22 AM
fuel tanks can be welded but they have to be cleaned well first, then completely full of water when welding.
excaleagle42 is offline
Old 04-24-2002 | 10:46 AM
Get a hold of Imco in southern cali and have them build you a custom one. They did a great job on the ones for the 38 footer is used to run.
Rick
scarabrick is offline
Old 04-25-2002 | 08:50 PM
Thanks for the feedback Guy's.
TomR is offline
bigboat28
Pantera
4
08-04-2008 11:35 AM
cougarman
Apache
13
03-22-2005 07:57 PM
SLINGSHOT
02-10-2005 07:32 AM
ROADHOG
Sonic
6
08-31-2004 06:21 PM
XCAV8
4
07-09-2002 10:35 AM
