Engine oil cooler leaking
I hate the winter!!
I just finished the install of my new engine the other day. The engine fired up fine, but my Hardin Marine oil cooler sprung a leak. It was fine last year. All I did to it over the winter was wash it out in a parts washer and repaint it. Its only a couple of years old. The cooler is spraying a small stream of water out, right on the solder joint, where the tank meets the cap. I am thinking of trying to solder it shut with the same stuff you would sweat copper pipes together with. What do you think?
