new lenco hp 25x14 tabs
anyone have any feedback on these? just getting ready to install k-planes but like the 25x19 dual ram performance series i seen on lencos sight - 24'excalibur - i sure could use the room not running the hydro pumps! thanks in advance
i used the smaller version of the Lenco HP tab on my 21' Baja. They worked great. Make sure you get the better LED indicator switch with the kit. Install #12 AWG wire for power and use good terminations. Kit screwed into the transom so higher MPH is not wise unless your through bolt them. Again, not a bad set at all for tight spaces.
