Oil temp sensor? >
Oil temp sensor?
Oil temp sensor?
Old 05-17-2011 | 01:43 PM
Livorsi sells all the various senders
BenPerfected is offline
Old 05-17-2011 | 02:23 PM
Originally Posted by blue thunder
That looks like an oil pressure switch. Senders will only have 1 wire going to them.
I think it's actually the choke switch.. If it's a carbed motor. My carbed HP500 has a switch exactly like that on the remote filter pad, and it's the switch for the choke.
Eliminator28 is offline
Old 05-17-2011 | 04:00 PM
It's actually an oil pressure switch... for the choke circuit. It doesn't allow voltage to the choke coil unless the engine is running. That way if the key is left on without the engine running, the choke coil is not inadvertently warming up and opening the choke without the engine running.
In a factory Merc harness, the wire for the oil temp sender is dark brown, or dark brown with a white tracer. As Eddie stated, 3/8 NPT in the block, just above the filter pad, is the best placement for the sender.
cubicinches is offline
Old 05-17-2011 | 10:50 PM
I was wondering if it was a standard GM part? I'll just get Mercury ones I guess from BAM
Irishtornado is offline
Old 08-23-2018 | 11:04 AM
Default Oil Temp Sender
Originally Posted by Young Performance
The best place to read oil temp in a Gen VI block is the 3/8" NPT port just above the oil filter pad (where the oil filter would be in a car). The pressure sender will be there, so you will have to move it. You can put it in the port just above the bell housing, the filter housing, or in the 1/4" npt port on the side of the block just above the oil pan rail near the front. You want the oil temp sender in the flow of oil, not a dead end passage that has stagnate oil. The port I mentioned is the absolute best place. The pressure sender can go anywhere, even if it is in a dead end passage. Pressure is pressure. You want to know the temp of the oil that is going in the engine. Good luck. Give me a shout if I can help.
Eddie
Bring this old tread up to determine if my oil temps are inline. Does any anyone know if the location Eddie mention above the filter pad is reading before the oil cooler or after? As this is where I'm taking may reading from for my oil temp gauge.
Donzi1979 is offline
Old 08-23-2018 | 05:23 PM
Originally Posted by Irishtornado
I'm having same issue. Just switched from a 496HO to a 500efi and now my oil temp gauges don't work...Actually can't recall if they worked on the 496's either. Any advice? The gauges are wired as I put new gauges in 2yrs ago. I'm guessing it's the sensor wire or the senders aren't in the right location to read correctly. My boat runs 155 degrees on water temp so oil should be within 10-20 degrees I would imagine. It doesn't even move on the gauge.
Oil temperature in a high performance boat could easily be 100+ degrees higher than the coolant.
underpsi68 is offline
Old 08-23-2018 | 06:10 PM
My oil temp sending units were mounted in the rear port side of the engine block just above the oil pan. Single wire sender.
Interceptor is offline
Old 08-23-2018 | 08:26 PM
Rookie's Avatar
After the cooler. This is the temp that the oil is before the oil goes to your bearings, the important temp. If you want to have one in the pan or before the cooler to see how hot your oil gets, do this as a secondary sender and just use a toggle switch to toggle between senders. This will tell you how well your cooling system is working.
Rookie is offline
Old 08-24-2018 | 05:12 AM
Full Force's Avatar
My 87 Gun has them in the pans, I prefer to read after cooler but in this case I still don't see more then 180 IN PAN! (hot side) at them temps I am not worried, so I have not moved them yet, new gauges and senders and verified with temp laser, so look down by your pans especially if Hawk powered with GIL pans, very common place, wire is single Brown.
Full Force is offline
