cost to polish imco lower? >
Old 06-02-2010 | 06:26 PM
Default cost to polish imco lower?
what do you think it should cost to have a imco -2 lower polished? thanks
Smoothsix is offline
Old 06-02-2010 | 11:40 PM
IMCO wouldn't waste your time you'll have to polish it ever time you go in the water if you start...Leave it satin and just hit it with acid once in awhile if you want the bright look.
Irishtornado is offline
Old 06-03-2010 | 10:33 AM
fireboatpilot's Avatar
RIPSTA Racing Team
I've heard that polishing the lower could actually slow you down? It was the rougher surface of the satin lower that allowed the water to be released from the metal as it passed over it. The water would actually stick to the polished surface thus slowing you down? Is this possible?
fireboatpilot is offline
Old 06-03-2010 | 11:10 AM
CB-BLR's Avatar
Chris
Actually...
The water molecules stick somewhat to the rough surface creating a thin skin of water. The water passing around the drive then is slipping over a thin layer of water... water slipping over water has less drag than water slipping over metal.
You can see this by the fact that submarines (and dolphins) have a semi rough surface to apply this principle.
I have seen the polishing of a lower unit loose 1-2 mph.
Chris
CB-BLR is offline
Old 06-03-2010 | 11:21 PM
what kind of acid to keep it bright do you use ? thanks
Old 06-04-2010 | 01:11 AM
Muratic acid. Don't use all the time though. Just when it gets pretty dull.
Griff is offline
Old 06-04-2010 | 06:21 PM
just wipe on and wipe off ?
Old 06-04-2010 | 06:26 PM
JasonSmith's Avatar
I use SOS pads with the soap in them instead of acid. You can buy em at the Dollar General & they work really well.
JasonSmith is offline
Old 06-04-2010 | 06:57 PM
tmdog's Avatar
Unless you have a lot of time on your hands, go ahead and waste it. Smart money says to use something other than polish.
tmdog is offline
Old 06-04-2010 | 09:09 PM
Smitty's Avatar
I mix 2 bottles of Sno-Bol toilet cleaner with about 1.25 gallons of water and I spray any areas of the glass that is loking dingy along with my satin lowers. Let sit for a few minutes and hose off. Drives look like new and the glass is pure white. Just don't do this on concrete or it will look white also
I agree that polishing the lower will actually increase drag and loss of speed. I have sanded/scuffed the bottom of my boat to make it rough and it has actually gained speed at all rpms.
Smitty is offline
