holey carb gurus >
holey carb gurus
holey carb gurus
Old 06-11-2010 | 06:44 AM
  #31
Thunderstruck's Avatar
Originally Posted by rssteiny
What size cams are you running, how is it working this year.
I run Bob Madara's cams that are ~228 I, 232 E duration with ~.598 lift on both I & E, pretty mild idle but they pack the charge in really well on the top end. Peak hp is at 5500 rpm. I am still in the 90-91 mph range but looking to do another project with Bob this year to take it up another notch.
Long time cult member.
Thunderstruck is offline
Old 06-11-2010 | 07:32 AM
  #32
You spinning 30s at 5500 with nose cones right.
rssteiny is offline
Old 06-11-2010 | 08:39 AM
  #33
yep.
Old 06-11-2010 | 10:30 AM
  #34
Try cleaning the air bleeds with some carb. cleaner, by sticking the red nozzle into the air bleeds. This carb. worked well once upon a time. Also a blown power vale will cause ir to be rich at idle.
45SS is offline
Old 06-11-2010 | 11:05 AM
  #35
rvtransport's Avatar
I would first warm engine to operating temp set floats, and then set timing. I would run as much intial timing as possible at least 14 degrees with full advance around 35 to 36. Then set idel mixtures to max vac or rpm usually 3/4 turn out. should idel about 950 out of gear. put boat in water and install vac gauge. make sure when ideling in gear u do not drop vac under your power valve vac rating which is usually a 6.5 vac rating. If you are below that you need to change powervalve to lower vac opening then in gear idel vac. Just my 2 cents good luck!
rvtransport is offline
Old 06-11-2010 | 11:48 AM
  #36
Throttle Fever's Avatar
Thumbs up
That how we do them, Great advise... Pete
Throttle Fever is offline
Old 06-11-2010 | 12:27 PM
  #37
Just a thought but my carbs were set up by Dean at Nickerson's and have always worked perfectly till I got my first tank of fuel with alcohol then they idled just as you stated all the carbs needed a extra 1/4 turn at each corner in the idle circuit. then they were back to there normal idle
eliminatethis is offline
