Oil Temp Sender Location >
Old 07-23-2010 | 08:35 AM
jayhawk261's Avatar
Default Oil Temp Sender Location
I'm considering adding an Oil temp gauge as I just went to a mechanical drive indicator and need to fill a hole on the dash. I'm thinking it could be installed at the oil filter relocation point (engine was a 2000 454 MAG MPI) at the front port side of the engine. Would the sender go into the supply or the return from the filter? Also, does anyone know where I might find an adapter to place at this point that will have a hole for the sender?
jayhawk261 is offline
Old 07-23-2010 | 08:41 AM
SpeedDoc's Avatar
Charter Member # 302
I Like to put my oil temp senders after the cooler so I know how hot the oil is going back into the motor. My last boat had one in the pan & one after the cooler so I could see how well it was cooling.
Also, you can take any aluminum oil filter bracket and drill & tap it for the sender.
SpeedDoc is offline
Old 07-23-2010 | 08:53 AM
jayhawk261's Avatar
That sounds like a good idea. I have 2 coolers on mine so after the second one would be the spot for that.
I'm using the factory filter mount so I'm assuming that is aluminum. I suppose I could drill and tap that as well. Although I'm not sure if it would still fit in the mounting bracket with the sender sticking out the side.
