1989 454 max RPM >
1989 454 max RPM
1989 454 max RPM
Old 08-06-2010 | 01:39 PM
Default 1989 454 max RPM
Just bought 89 Pachanga. What is the max rpm for the 454 330hp engine? Also does anyone know the normal operating range for oil temp?
Kent
kentbrookins is offline
Old 08-06-2010 | 02:16 PM
42-4600 rpm. 140 degree thermostat...........
AngerMgmt is offline
Old 08-06-2010 | 05:03 PM
thank you
Old 08-06-2010 | 05:42 PM
mcollinstn's Avatar
Oil temp up to 245 is fine.
You actually want your oil to run over 215 to keep the moisture out.
mcollinstn is offline
Old 08-06-2013 | 09:17 PM
Just got a 27 pachanga 454. Runs only 4200 @ 40 mph. Also low temp
Is this normal?
slotcop is offline
Old 08-11-2013 | 10:19 AM
Is this normal?
Low oil temp could be good or bad, just depends on how low you are talking about. As stated above, you want the oil at least 200ish.
Congrats on the Pachange, P-27's are hard to find with twin big blocks. Where did you find her, and please share some pictures.
suss1173 is offline
