Help converting to headers on a SBC >
Old 08-21-2010 | 03:59 PM
Here's my existing thermostat housing:
I have a power steering cooler on the starboard side of the engine, which is inline with the water coming from the sterndrive and up into the thermostat housing from the starboard side.
It seems like MOST thermostat housing I am finding have the water intake on the starboard side. This stainless one looks great, apart from the which side has the water inlet, and I'm just wondering if I should
1. Keep looking, but so far nothing else looks like it'll work.
2. Reroute the direction of the water inlet by flipping the fitting on the gimbal housing, and then trying to mount the power steering cooler on the port side, then try to find a hose to use that stainless thermostat housing?
3. Keep the power steering cooler on the starboard side, and run a hose UNDER the engine up to the thermostat housing.
I'm totally lost here. Why is it that every single stock looking thermostat housing has the inlet on the starboard side... but the only aftermarket one for use with headers has an inlet on the port side? Doesn't make much sense.
cash68 is offline
Old 08-22-2010 | 11:13 PM
The Stainless one is exactly like all the newer Merc MPI T stats housings.
http://www.mercruiserparts.com/Show_...SING+%26+HOSES
You can use that and reroute the hose or you can get some Y fittings made to connect the two hoses on each side together. Those are going to be the only options.
Griff is offline
Old 08-23-2010 | 10:43 PM
How do you not hit the alternator and stuff though? Seems like it would be in the way. Also, I tried reversing the fitting on the gimbal... no dice. I suppose I could run a huge long hose under the engine and come up on that side, but it's going to look like ****ing ass. Can somebody show me a properly setup marine engine with headers?
cash68 is offline
Old 08-25-2010 | 08:53 AM
How would you run the hose with the alternator?
cash68 is offline
Old 08-25-2010 | 09:55 AM
Default Fixx
First you need to get a 2 port housing,, then go from their..if you have room under the housing all you will need is a 135* hose to go under it then to your oil cooler and your done..
FIXX is offline
Old 08-25-2010 | 12:41 PM
88Fount33's Avatar
Beak botr
I would suggest going to ebasic power dot com and then looking through all their water inlet hoses that are the correct size find one for some other engine application that has a 180 bend (molded in) and a long run and run it to the starboard side. You must be diligent looking through all their hose offerings for all the different engines to find one with the right premade bends in it. Personally, I have NEVER seen a set up like you have stock.
88Fount33 is offline
Old 08-25-2010 | 02:23 PM
I have to agree,,dont forget we are talking a boat from 1978 and going from the ols log style manifolds to stellings..the next issue is going to be the tail pipes going to the tips under the swim platform..
FIXX is offline
Old 08-25-2010 | 05:26 PM
If you type in "thermostat housing" on ebay, and search for something that fits a GM V8, every single one looks a lot like my existing thermostat housing.
cash68 is offline
Old 08-25-2010 | 05:27 PM
No, the headers go over transom. What I don't understand is how people did this back in the 70s. Tons of jet boats had headers, and I'm not sure how any of them made it work with the thermostat housings that comes with most engines.
cash68 is offline
Old 08-25-2010 | 07:00 PM
Default Fixx
back in the day jet boats didnt have a waterpump on the engine,they use whats called a crossover that elinimated the waterpump,the jet pump fed the engine its water supply and dumped the excess through a pressure relief valve...http://eddiemarine.com/store/cart.ph...l&p=11551&c=40
then they changed the thermostat housing to a 2 port with a bypass in it so it couls keep the headers cool when you first start the engine untio the thermostat opened. http://eddiemarine.com/store/cart.ph...l&p=11561&c=52
so that thermostat housing i posted looks cheep now rite
Get it buy a 135* hose and go with it..
http://acehose.com/silicone-radiator-hoses.htm
FIXX is offline
