Starter Problem >
Starter Problem
Starter Problem
Old 05-06-2002 | 07:45 AM
INCOGNITO
Angry Starter Problem
MY BOAT DOESNT EVEN HAVE 5 HOURS ON IT AND ALREADY STARTER TOOK A DUMP-YES STARTER IS OR WAS BRAND NEW-ITS A API MARINE STARTER SUPPOSEDLY MINI HY TORQUE DEAL.CAN ANYBODY RECOMMEND SOMETHING STRONGER THAT WILL LAST-COULDNT I JUST PUT LIKE A TILTON OR CSI DEAL .ITS A LOW MOUNT..MOTOR IS A N/A 588 CID PUMP GAS . ANY INFOR IS GEATLY APPRECIATED...
Old 05-06-2002 | 09:37 AM
Audiofn's Avatar
Charter Member #232
I have had very good luck with the starters from Boat US. They have a huge list of starters to choose from that will fit your aplication.
Jon
Put your best foot forward!
Audiofn is offline
Old 05-06-2002 | 06:24 PM
blue thunder's Avatar
That is very odd. What exactly is it doing, or not doing?
BT
blue thunder is offline
Old 05-06-2002 | 08:19 PM
MSD makes a switch that retards the timing on just on startup for easier starts. it may help.
excaleagle42 is offline
Old 05-06-2002 | 09:50 PM
Default ignition on delay
if the advance on your ignition system is loading the starter you can install a seperate ignition kill switch and turn ignition on after the motor is cranking at full speed.
formula233 is offline
Old 05-06-2002 | 10:28 PM
merlin540
just spend the money and buy a tilton marine starter it wont let you down
Old 05-08-2002 | 10:52 PM
cartman
Check main ground to engine block
T-Mone
Do It Yourself, Boating on a Budget
28
10-20-2008 08:02 PM
BOATING ON A BUDGET
2
04-26-2005 08:43 PM
cooltoys61
5
03-16-2005 11:53 AM
freeman1
6
11-04-2002 08:09 AM
