gauges
Old 08-23-2010 | 02:20 PM
Ken N's Avatar
Arrow gauges
Having all the gauge that come with the stander package what other gauges are good to have.
Ken N is offline
Old 08-23-2010 | 07:09 PM
Elite Marine's Avatar
Depends on engines - Vac/Boost, Fuel Pressure, Oil Temp, Drive Temp.
Let me know if we can help.
Kirk
Elite Marine is offline
Old 08-24-2010 | 12:41 AM
Water pressure & Oil temp
Griff is offline
Old 08-25-2010 | 09:08 AM
Ken N's Avatar
Arrow gauges
Where is the best place to install a water or oil temp senders.
Ken N is offline
Old 08-25-2010 | 06:56 PM
Water pressure is easy to set up mechanical with a small hose from the intake manifold to the dash. I suggest the oil temp gauge at or after the oil cooler....maybe the oil filter housing depending on your rigging. If you want a high oil temp alarm, we have this sender in the oil pan.
BenPerfected is offline
Old 08-26-2010 | 10:25 AM
Ken N's Avatar
Arrow sender location
I would like to use a electric senders. What i have is a 502 MPI not much space to work with, i do have a plug in the therostat housing can that be used for a water pressor sender?.
Ken N is offline
Old 08-26-2010 | 11:42 AM
Water pressure guages are always mechanical. You can just install the tube and fitting into the intake manifold or into a block drain. The ones installed in the block drain tend to clog easily if you have boat where there is sand in the water.
Griff is offline
