Best way to check stringers while engine is out? >
Old 08-31-2010 | 09:58 PM
Default Best way to check stringers while engine is out?
Just took the engine out of the boat a few weeks ago and I'm going to have a new one built with quite a bit more power as mine was the 330hp 7.4 stock motor on my 272, I wanted just to verify that my stringers are still in good shape since it's a 1996. What is the best way to verify? they look good but I didn't know exactly what the correct was to verify that they are nice and strong? Since I have the engine out wouldn't hurt to do this. Any help would greatly be appreciated thanks!
272bajadriver is offline
Old 08-31-2010 | 10:19 PM
If your not confident yourself find someone with a good reputation to check it out as well as the transom. Your prob OK but it pays to be safe...
POWERPLAY J is offline
Old 08-31-2010 | 11:23 PM
c_deezy's Avatar
Tap on them with a brass hammer or the end of a plastic screwdriver. Listen for a loud rap, not a dull thud, or listen for tone changes as your tapping.
c_deezy is offline
Old 09-01-2010 | 07:33 AM
a hard plastic hammer is great...just listen as said
ezstriper is offline
Old 09-01-2010 | 05:49 PM
offthefront's Avatar
as stated tap with a screwdriver handle ...you can tell from solid and not solid ...if you find a suspect spot you can drill a hole (1/4-3/8) and it will show if there is moisture/rot ...m
offthefront is offline
