loosing drive fluid in bilge ?? >
Old 09-06-2010 | 10:10 PM
wild mike's Avatar
Default loosing drive fluid in bilge ??
I replaced my bottle because the bottom was covered with gear lube and it was empty(thought it was cracked), I fill it up and after an hour it was empty again and i noticed the bilge had gear lube in it, any ideas how the lube can get from the drive to the bilge ? this happened several times today
wild mike is offline
Old 09-06-2010 | 10:16 PM
alot of times that line is spliced by the transom housing see if its leaking there or rubbed through
mike11 is offline
Old 09-06-2010 | 11:57 PM
Sounds like a bad seal in the drive pushing pressure out to the bottle and into the bilge. Prob a yoke seal.
GTOFFSHORE is offline
Old 09-07-2010 | 01:46 AM
Mbam's Avatar
Offshoreonly Advertiser
What drive?
Mbam is offline
Old 09-07-2010 | 06:49 AM
I had this happen twice to me over the last two weeks. Come to find out, somehow I lost the gasket that goes in the top of the cap. Made a new one, and no problems since.
07DominatorSS is offline
Old 09-07-2010 | 07:14 AM
t500hps's Avatar
21 and 42 footers
Assuming its a bravo drive it sounds like the input shaft seal of the drive is leaking into the bellows, then overflowing through the transom assembly into the bilge. If so be ready when you pull the drive, it's going to pour drive fluid all over the place!!!!
t500hps is offline
Old 09-07-2010 | 07:57 AM
Turbojack's Avatar
I will go with the plastic bulkhead fitting going from the drive bottle to the fitting in the outdrive.
Turbojack is offline
Old 09-07-2010 | 08:54 AM
wild mike's Avatar
thanks guys, it is a bravo drive
Old 09-07-2010 | 08:58 AM
bajarick's Avatar
The cap on the bottle had a bad seal on mine
and would leak out when running in gear, theres
7 to 9 pounds of pressure when you run it in gear.
Try new cap and seal.
bajarick is offline
Old 09-07-2010 | 10:37 AM
wild mike's Avatar
it's not leaking out of the cap, bottle is clean, it must be the hose or something with the drive seals
