Setting timing on a 575sci >
Old 09-16-2010 | 08:44 PM
Default Setting timing on a 575sci
I am trying to gather some info on setting timing on my 575's after my rebuilds and have a few questions. My manual tells me that I have two options:
Option 1: Use the digital diagnositc tool - don't have
Option 2: Use the mercruiser timing tool - don't have
From the picture, I beleive I can just jump A and B on the data link connector on my harness which should set me to 8 degrees BTDC... correct? At that point, I need to throttle to 1800 rpm, check timing, verify that it is 8Deg BTDC. Once set, idle down, shut down and tighten distributor.
That should be it correct?
teamsynergy is offline
Old 09-16-2010 | 10:07 PM
Use a paperclip to jump the A and B terminals. Then set the timing to 8* BTDC. You can rev it up a little to help stabilize the timing. It won't move when you rev it up, it will just stop it from bouncing around.
Let me know if you need any help. Just give me a shout.
Eddie
Young Performance is offline
Old 09-17-2010 | 05:30 AM
Thanks Eddie...
Old 09-17-2010 | 07:04 AM
obnoxus's Avatar
Charter Member #1171
where in Ind are you?
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 09-17-2010 | 07:10 AM
South Bend Area
Old 09-17-2010 | 09:59 PM
Originally Posted by teamsynergy
Thanks Eddie...
My pleasure. Give me a shout if I can help with anything.
Eddie
