Good Speed Sensor - Pulse Style >
Old 10-04-2010 | 01:21 AM
Default Good Speed Sensor - Pulse Style
Looking for a pulse or wheel style speed sensor that's good above 75mph.
Need to feed an ECM for mileage calculations, so my Garmin GPS head won't do it. Everything I've found so far is rated at 75 or less.
Any suggestions?
-K
kidturbo is offline
Old 10-04-2010 | 04:26 AM
What type of application are you using it on?
smcser is offline
Old 10-04-2010 | 01:01 PM
It's going to a automotive ECM on a duramax diesel in a boat.
Wants to see a 5V pulse signal where X amount pulses = 1 mile. I can calibrate the ECM to the sender, just trying to find something rated at higher speeds.
-K
kidturbo is offline
Old 10-10-2010 | 06:19 PM
Any suggestions?
-K
-K
The mercruiser smartcraft system has a 80 MPH or greater pitot speed sensor kit, that goes up to 1379 kpa (200PSI). Part number 881879A3.
Also mercruiser has a through hull depth/speed sensor with a (19 ft.) wire harness. Part number was 883090, But the number has now superseded to 883090A01.
But unfortunately the listed information does not say what speeds the through hull fitting is capable of doing.
You can copy and paste the part numbers in the link below.
http://www.mercruiserparts.com/partsByNumber.asp
Good luck with it.
Boat Tech is offline
Old 10-10-2010 | 08:39 PM
Thanks, will check that one out.
-K
kidturbo is offline
Old 10-11-2010 | 06:12 AM
I'm not sure how accurate you need the speed to be. But since speed increases fairly linearly with rpm on a boat ,you could use a sensor on a flywheel or crank pulley mounted reluctor.
I am curious why you want/need the vss, just for milage?
rdoactive is offline
Old 10-11-2010 | 08:32 PM
Yeah I want to log some mileage and engine load data under different prop setups, ECM tunes and fuel blends. If I can get a reliable speed signal in there it makes things much easier..
-K
kidturbo is offline
