looking for a littel more power >
Old 10-12-2010 | 06:43 AM
Registered User
Default looking for a littel more power
pulling engines this winter to check/fresh want to see what everyone thinks heres what i have.540x2 short deck.950hp holleys world merlin int. world merlin 320 heads dart blocks callis d/s cranks manley rods je pistons 9.2 comp. hyd roller cams 611int/596ext 234/240@50 gill manifolds dry tails throug trans msd ign. thanks tell me know what yall think
itbs is offline
Old 10-12-2010 | 07:28 AM
PatriYacht's Avatar
My guess is your engine makes about 550-575 hp the way it's set up right now. Sorry but those heads are not much better than stock GM rect. port heads, the cam is short on duration and lift, and a 950 Holley actually has the same size venturies as a 750. A bunch of OSO members have 650-700 hp 540's running around but the cost is so high , new heads, cam, Dominator carb and manifold, it would be worth while to put a blower on it and make more.
PatriYacht is offline
Old 10-12-2010 | 01:47 PM
Registered User
what do you think should be on them carb.intake heads cams anyone else have thoughts
itbs is offline
Old 10-12-2010 | 02:30 PM
PatriYacht's Avatar
AFR 315 CNC heads, Edelbrock Victor intake, 1050 Dominator carb, custom cam with a bit more duration and lift and maybe 1.8 rockers on the intake side. 10.0 - 1 small dome pistons by JE-SRP. This combination will make 700 hp in a 540 and idle nicely at 800 rpm. Problem is, the heads cost all most as much as an 8-71 blower.
Old 10-12-2010 | 03:53 PM
Registered User
do not have hight and no scoops
itbs is offline
Old 10-13-2010 | 02:58 PM
Registered User
what do you think about carbed prochargers
itbs is offline
Old 10-13-2010 | 03:42 PM
fireboatpilot's Avatar
RIPSTA Racing Team
My engines responded well to a set of Merlin "X" intakes and AED worked 1050 Dominators.
fireboatpilot is offline
Old 11-02-2010 | 12:48 PM
Registered User
ok on heads& intakes what about cams
itbs is offline
Old 11-03-2010 | 06:37 AM
I think intakes and 1050's..carbs to small
ezstriper is offline
Old 11-03-2010 | 07:47 AM
Turbojack's Avatar
If you go M1 with 5 lbs of boost you will be OK, Any more then that you really need to go EFI. Look into Rtech intercooler with vortex
Turbojack is offline
