Why is my distirbutor buzzing >
Old 10-18-2010 | 12:35 AM
Default Why is my distirbutor buzzing
Thought i'd try out these Mallory marine ignitons this time arround. I know a couple guys that tried them and they worked fine. This is the first time that I have installed them.
When I turn the key on, it starts buzzing. I re checked the wiring diagram, There are only 3 wires and they are all hooked up correctly.
havn't actually tried starting the engine yet as there are a few things to sort out first.
Anyone installed these ignitions yet and had positive or negative experience.
Guess I should have just gone with good ole MSD????
Could this be a low voltage problem as well? The battery was dead from sitting for a while. Been on trickle charge all day and tonight. I can check again tomorrow and see if the problem goes away...??
jeff1000man is offline
Old 10-18-2010 | 05:43 AM
I ran a unilite and worked fine..stand alone no box...see if it runs ?? they have a very simple adj advance set-up that I like..
ezstriper is offline
Old 10-18-2010 | 09:41 AM
Default Fixx
if its a unilite you need to run a resister,anything over 8 volts and the electric eye will burn out...the buzzing is probably from having the battery charger on..
FIXX is offline
