Engine temps with cooler weather?
Jeff, How ya been as well!?! I was runnin yesterday. 50degrees and the ater was cold. I think i have a different style of thermostat housing and i have the gils with the big boy risers. she ran the exact same temps and 1mph faster. the cold air is prob the only thing that helped. but i did notice it took me a longer warmup to get my oil temp up to at least 140. prob from the cold water. mabye because it was 30 the night before and it just took longer to warm the olde girl up.
good luck jeff!
Wonder if you used a different temp sender to fool the ECU to go into closed loop mode? Used something simliar in my snowmobile. It was basically a trick air temp sensor. The snowmobiles EFI added fuel or subtracted fuel based upon air temp readings. Mine was designed to trick the ecu into thinking it was warmer out than it really was, which leaned the sled out a bit(they were pig rich from the factory). Woke the sled up quite a bit!!
Or maybe get some brass gate valves from the hardware store and plumb them in. Adjust the valves accordingly to restrict some water to the manifolds, but i'd watch water psi inside the block..
Good ideas, its only a problem a few times a year. Not a big deal until you want to race. I ran a 27' Advantage with a Merc (blue motor) 500HP and could not keep up. He said he was hitting 74. Just a few weeks ago I was hitting 74-75, now with the temps even cooler I could only hit 72. I was expecting to hit 76 for the first time, a little disapointing. I will experiment with the hoses in the spring.
I can set my targets for entering closed loop with the laptop. The engine runs good when cold, and if you change the target for entering closed loop to a lower temp it removes the cold temp enrichment. The engine likes it rich untill its warmed up.
I ran a sunsation single. dont know how long it was. prob anywhere from 24-28ft. it had a 454 with a whipple. we ran and i got him. not by much but a good little walk away. but i was running my 4 blade and the chine just annoys me. need to get my k-planes figured out and install my hydraulic steering.
I may try that also. The other thing I thought about was replacing the high flow thermostat with a regular (lower flow) thermostat. I would think it should retain water in the engine longer and dump more water through the bypass hose.
