Water pump removed question.
This motor is from another members boat.My question is how did he remove the engine water pump? It looks like it has a crome pipe there. How is the water circulated without a pump? Where can I buy it? Thanks Mike.
The only used crossover kit I have found that I was interested in was priced so high that it was only $25.00 more for me to buy a brand new one and not have to deal with buying replacement gaskets.
Anyway, let me know if this is something you might be interested in. Thanks, Mark
The water will be circulated by a raw water or sea water pump mounted usually low and right (left as you look at the front) on the engine. This pump is belt driven and takes water direct from the drive pickup, transom pickup or sea strainer via either of these, and pumps it into the engine via the intake hose on the crossover which mounts in place of the circulating pump on the front of the engine (that chrome pipe you saw). If there is another pipe leading out of this to the thermostat housing on the intake manifold, this is the bypass for the exhaust cooling.
If you have a raw water pump, you do not need a circulating pump on the front but apprently it helps to regulate water pressure if you do have one.
I hope this helps.
I hope this helps.
Yea, I had assumed that there would be a belt or 2 to replace when adding a crossover. I'm in the process of doing a bunch of bolt-on upgrades to my motor right now (intake, carb, msd ignition, stainless marine exhaust, relocating the tips to above the water line, roller rockers, new fuel system, etc....) so I'm at that point where if I can get my hands on a crossover at a reasonable price, right now would be the time to do it while everything's apart and the rear seat assem. is out of the boat. I don't think I'm gonna want to deal with the crossover after I put everything back together. There's just not a lot of room in my engine compartment at the front of the motor because of the back seat and it's an absolute P.I.T.A. to remove!
I have cross overs and probably going to go back to stock water pumps this spring. It keeps the temps more stable.
The HP gain is so minimal, its not worth it.
But it gives you one other possible problem, Water Pressure as in to much.
The HP gain is so minimal, its not worth it. Are you running a water line from the rear of the manifold to the front? Also are you running a thermostat?
It's setup just like in the picture above. I only have them because they came on the original engines before I purchased the 502's.
