502 valve springs >
502 valve springs
502 valve springs
Old 11-25-2010 | 12:13 AM
Default 502 valve springs
I have a 502 carburated, with aluminum elderbrock heads. Has 150 hrs, wondering if its time to check and or replace valve springs and retainers hear a lot of the blue motors needing this. Just wondering is mine is the same or not?? Thanks in Advanced...
himself is offline
Old 11-25-2010 | 12:20 AM
What are the cam specs???????? Cam lift and the quality of valve springs used will determine a lot.
Griff is offline
Old 11-25-2010 | 12:57 AM
Not sure, bought it new from dereberry performance marine in 2002. Been a great motor just not sure if its time to start checking things b4 there's issues. Was advertised as 502/500 horse...
himself is offline
Old 11-25-2010 | 10:25 AM
Like Griff said.
And where do you typically run the engine ?
If it spends alot of time at the upper rpm ranges
it will need attention sooner.
I would hope though, at 150 hrs. they should still be ok.
JaayTeee is offline
Old 11-25-2010 | 11:44 AM
Probably a slightly modified GM crate engine then. I would think you are ok for at least another 50hrs. The Merc 500HP's generally start needing springs around 200-250hrs. The carbed 500's used bad springs so some of them had issues earlier.
Griff is offline
Old 11-25-2010 | 11:45 AM
Griff and JaayTee... thanks for the advice. I run it between 3800 to 4600 rpms mostly... with some bursts to 5400 rpms. its a great motor, just been reading lots of threads about valve spring failures at 150 or more hours, granted its the blue motors but wasn't sure. thanks again.
himself is offline
