XR Damage
#31
#32
No ignorance. Asking is usually how you make a decision or learn something.
#33
#34
XZ gears have a much finer helical cut face. The setup needs to be perfect for long life. The XR is a straight cut similar to gears used in a tractor. They are much more forgiving on the setup.....
#35
The SCX on the other hand uses totally new gears, much larger, that wont fit in an SC or XR case.
#36
What I see in your pictures, is just the nature of the beast. It does happen, but I can say not very often, I've been building outdrives for 30 some years, And Bravos ever since they've been out. I have had very little trouble with XR gears. And I've done many of them on all sizes of boats from 700hp and down. And very very little failure. They are a fussy gear that needs to realy be set properly. There is no room for error. I've got large boats with 700 plus hp and getting 400 hours and better on them. A lot of my customers are Poker Run customers. So they run hard.
#37
So they built a drive using the same gear that is still a little "better" than the XR depending on how you look at it.
There are NO cathodics so you're screwed in salt but the case is designed way better in my opinion. It moves a much higher volume of oil around. The cooling shower is built in and distributed nice and even. Finally, the case is thicker in areas and is built to lower the amount of tower flex and movement so everything is better "contained".
I've been to their facility a couple times and took some tours. It's a super nice product but mainly for fresh water use.
#38
Here is my lower driven gear with 59 hours at 800hp and 25 hours at 750hp. Pushing a relatively light boat at around 4600lbs.
#39
I too have a growing collection of junk
XR gearsets, from my own boat and a friends.
I also originally thought that it was driver error or
set up issues also( before I had a boat with XR's) but it's
not.
Seems like it's a 50-50 chance on getting a good set.
I equate it to laying down sod over dirt that is
littered with junk.
It looks good initially, but pretty soon the uglyness
starts showing up
I've had them pit out ( like the pictures), crack and shear the cone off the gear, and the fun one, break a tooth off and junk out the case.
If and when the next set crap out, I'll probably switch
to X gears
not.
littered with junk.
starts showing up
to X gears
