-   -   Dart 8.1 Gen 7 Iron Heads (https://www.offshoreonly.com/forums/general-q/245432-dart-8-1-gen-7-iron-heads.html)
jmccart 01-10-2012 12:13 PM
Originally Posted by crayolacrazy (Post 3589975)
short blocks done, will see what this is going to cost with these dart heads my stock heads are cncd bigger valves bronze guides .I think the dart can be better but at what cost Im not trying to make more power Im all ready over 810 hp im trying its a pian in the ass trying to get these heads done.
Over 810, NA, with stock heads sounds pretty amazing. So you have a running engine and the only thing you are changing is the heads? Sounds like a perfect product test.
I hope you are not hit with any extra machining requirements for you wallet.
I think I read that the Darts come with the narrower valve guides. Are you popping valves with 3/8" stems in the Dart heads?
Rage 02-18-2012 05:00 PM
Originally Posted by crayolacrazy (Post 3589817)
I got a set of the Dart heads today ,Im not sure if it was a mistake yet .Im going to have them flowed , and a few changes,like valve size , compare it to Tylers cnc head.From the nakid eye I think I went backwards they dont have bronze guides, the spring seat is small,
Hey, I see I have been asleep while things have been popping. Sounds like I am too late but I had talked to Dart a while back about the changes I would like in the bare Dart head to fit my current HP3 valve train parts. They said that I could spec the Dart heads to be made to fit the 3/8 valve stems + thin wall bronze guides, bigger diameter spring seat and custom spring seat depth. That way I could reuse my current valve train components except probably the push rods.
What are you having done to the heads.
Did you ever get the heads flowed? Numbers?
Rage 02-23-2012 03:55 PM
Rage 02-27-2012 08:53 AM
ttt
Raylar 02-27-2012 11:20 AM
Rage, why don't you just PM Crayola Crazy and get that info for yourself.
Best Regards,
Ray @ Raylar
Rage 02-27-2012 12:31 PM
Best Regards,
Ray @ Raylar
I did. Email as well. Waiting.
crayolacrazy 02-27-2012 07:18 PM
Originally Posted by rage (Post 3625322)
sounds like i am too late but i had talked to dart a while back about the changes i would like in the bare dart head to fit my current hp3 valve train parts. They said that i could spec the dart heads to be made to fit the 3/8 valve stems + thin wall bronze guides, bigger diameter spring seat and custom spring seat depth. That way i could reuse my current valve train components except probably the push rods.
you could do what ever you want, it just cost money. I have about 2500 with the valves spring upgrades no port work. I put larger springs, inconel exhaust valves ,larger 2150 intake valves . f **k it if its slower ill turn up the boost . If I loose boost we made HP.
crayolacrazy 02-27-2012 07:28 PM
my old heads 11/32 valve stems and ,learned that they didnt have inconel valves. 1 motor is all new complete new heads on the other.that my change when the heads come off.
Rage 02-28-2012 06:51 AM
Thanks. Did you get the heads flowed before or after adding the bigger intake valve ? Numbers?
What springs did you put in?
What cam are you running?
Rage 02-28-2012 10:19 AM
I hope it all turns out well.
I should have thought to ask before. Any pictures you could post of the heads showing the upper valve train complete?
