gen 5
Old 01-20-2011 | 02:37 PM
Default gen 5
how good is the gen 5 454
mudboy33 is offline
Old 01-20-2011 | 03:09 PM
Its not a roller cam engine, they only made them for 3-4 years if my math is correct. Requires a fuel pump mounted on the seawater pump or electric pump.
1BIGJIM is offline
Old 01-20-2011 | 03:33 PM
i had one that had a oiling problem "starved the valvetrain" after 2 rebuild's found out gen 5's were known for this problem. multiple shop's thought they had a casting problem somewhere that you couldent see.
Bill Mattingly is offline
Old 01-20-2011 | 06:17 PM
do you think a high pressure pump would help?
mudboy33 is offline
Old 01-20-2011 | 06:38 PM
Im converting mine to a roller, not cheap but hopefully will be worth it in the end.
antknee is offline
Old 01-20-2011 | 06:45 PM
that might be something for me to think about
mudboy33 is offline
Old 01-20-2011 | 07:40 PM
If your going to continue to run the fuel pump mounted on the seawater pump and your pump is good you can convert your 42 gph pump to a 130 gph by buying this and install the bottom half to your stock pump change your lines to 1/2 inch and you will be good.
http://www.jegs.com/i/Holley/510/12-454-13/10002/-1
http://www.jegs.com/i/Holley/510/712-454-13/10002/-1
Rockfish71 is offline
Old 01-21-2011 | 01:04 PM
Now you tell me, where were you two years ago? Could've saved me some money and got a better pump.
ThisIsLivin is offline
