Comp Roller Cam identification help.... >
Old 01-23-2011 | 03:07 PM
Default Comp Roller Cam identification help....
Not sure if there is anything that can be done to identify a cam i have but input is welcome.
i have a comp hydraulic roller custion grind that I ran in a 540 on the dyno only. It made over 600hp and was a pretty mild build. I was happy with that but then some other options came up.
So this was removed and has been on my shelf in a box for 3 yrs. I lost the card for it. Can you measure it somehow or look it up somewhere?
Baja226sport is offline
Old 01-23-2011 | 03:23 PM
GPM
There should be numbers on one of the ends, call Comp Cams they should be able to help you out.
GPM is offline
