HP 500 cam upgrade >
HP 500 cam upgrade
HP 500 cam upgrade
Old 02-20-2011 | 03:04 PM
Default HP 500 cam upgrade
wanting to upgrade my Gen VI HP 500 ( carb version ). I have a line on a HP 500 EFI cam ( little bigger )and a HP 525 EFI cam ( alot bigger ) Question: any problem going with an efi cam in an carb application? Will my current lifters work ? ( crane #13532 with tie bars ) will my pushrods work? of course I would like to go with the bigger cam if it doesn't require MAJOR parts, only because I have a big upgrade planned for next winter. Oh ya , I already have cmi headers so reversion shouldn't be a factor.
Rudd Jr is offline
Old 02-20-2011 | 07:08 PM
Reversion won't be an issue but leaky headers will be!
bob_t is offline
Old 02-20-2011 | 07:23 PM
Better make sure the cam has a lobe for the fuel pump if you are not running an electric pump
rexcramer1 is offline
Old 02-21-2011 | 09:20 AM
I'd leave it alone if your gonna be tearing it down next winter. The crane "741" cam works nice. Would also work nice if you decided to supercharge it.
MILD THUNDER is offline
Old 02-21-2011 | 09:31 AM
Panther's Avatar
Frank's Marine Service
I believe the 525 EFI cam is very close to the 741 with the firing order swap.
Panther is offline
Old 02-21-2011 | 02:39 PM
The 525EFI cam is a Crane 168741 that is ground with a 114 lob sep instead of the standard 112. It would be a good choice.
Griff is offline
Old 02-22-2011 | 03:27 PM
Rudd Jr
E mail me @ [email protected]
baja27 is offline
