alternator upgrade  55 AMP vs ? >
Old 02-21-2011 | 07:54 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Originally Posted by glen george
I was hoping for plug and play,not FIRE , im still running the 1994 55amp. looking at aftermarket .http://www.dbelectrical.com/ I think i will order the 65amp replacement.
As long as the existing wire is at least an 8AWG wire.
US1 Fountain is offline
Old 02-21-2011 | 08:13 PM
glen george's Avatar
My engine bay without the motor. wire upgrade will be easy . Fresh 540 to go back in this spring. Looking at the wiring diagram, its the orange wire fron the alt to the starter that i need to increase .
Attached Thumbnails alternator upgrade  55 AMP vs ?-imgp2493.jpg   alternator upgrade  55 AMP vs ?-imgp2494.jpg   alternator upgrade  55 AMP vs ?-imgp2483.jpg
glen george is offline
Old 02-22-2011 | 12:22 PM
I've been running DB's 105 amp. Definitely upgrade charge wire and connectors. They have awesome affordable products!
kennyo is offline
Old 02-22-2011 | 12:55 PM
Post a pic of your checkmate...can't tell too much from the avatar.
Thunderstruck27 is offline
Old 02-22-2011 | 04:07 PM
2010 onieda lake n.y. pictures. looking at the wire diagram, I know now what wires to upgrade. Thanks for the input.
Attached Thumbnails alternator upgrade  55 AMP vs ?-imgp2428.jpg   alternator upgrade  55 AMP vs ?-imgp2441.jpg
Old 02-22-2011 | 08:05 PM
I used to run a 65 amp on my Liberator and two batteries with no problems. Keep in mind most alternators make their rated output at 2000 rpms. If you idle a lot you will not be making full output and may want to go to a 90 or 105, but if a 65 will get the job done their is no advantage to going oversized.
rexcramer1 is offline
Old 02-22-2011 | 08:35 PM
I dont idle alot, but this year with fuel price$ up again, I may sit more and relax than up/down the lake.
Old 02-22-2011 | 09:40 PM
Make sure you have a wide enough belt- if you really up the amperage you need a wider belt.
I have 2-pc2150's a full nav system (with a 4KW radar) and run a 165 AMP alternator off a serpentine belt.
Balmar is a great resource for marine alternators and information.
Uncle Dave
Uncle Dave is offline
Old 02-23-2011 | 04:49 AM
1/2" belt. I ordered a 65 amp. Thanks for all your inpiut.
Attached Thumbnails alternator upgrade  55 AMP vs ?-mando%5B1%5D.jpg   alternator upgrade  55 AMP vs ?-amn0002_diagram%5B1%5D.jpg
Old 02-23-2011 | 11:55 AM
1/2" belt
balmar reccomends 110 amp max.
http://www.balmar.net/2011-Balmar-Product-Guide.pdf
UD
