weiand 177 for bbc question >
Old 03-05-2011 | 04:25 PM
Default weiand 177 for bbc question
ok guys i have looked everywhere and called summit, jegs, weiand/holley and checked all the stores i can find, i bought a used 177 blower and i need the crank pulley for it but i need the one that replaces the alum pully on the front on my 1990 gen4 bbci read the directions and it says if you have the alum. crank pulley on your motor disguard it and used supplied pullry in kit but there is no part number for that pulley and weiand/holley said they dont sell it seperate and wouldnt give me the part number, the pulley i have goes in the center of the steel pulley but i cant find a steel pulley with the smaill center groove for the sea pump, any help would be appreciated.... oh and its a 10rib belt set up
garmin0204 is offline
Old 03-05-2011 | 04:45 PM
Did you try CPperformance ?
jeffswav is offline
Old 03-05-2011 | 10:37 PM
i just looked online no luck but i'll give them a call on monday thanks
Old 03-06-2011 | 08:09 AM
I don't know who you talked to, but Tom @ wieand is the guy to talk to and they do sell the pulleys separatly...but I will warn you merc was very inconsistant on their pulleys and going to take some time to get it set up right..also I have a brand new 2.66 upper if you need one...Rob
ezstriper is offline
Old 03-06-2011 | 08:24 AM
Payton's Avatar
Charter Member #927
How about this?
http://www.cpperformance.com/p-14614...ft-pulley.aspx
Payton is offline
Old 03-06-2011 | 11:01 AM
I had a similar problem. My stock aluminum pulleys would not work with the blower crank pulleys. Ending up buying a bunch steel crank pulleys from a marine junk yard then having the centers machined to match. It was quicker than trying to match up the 100's of pulleys that are out there, and only cost me $30 for the machining and $50 for a box of pulleys. I think they were MarkV pulleys but not sure.
4bus is offline
Old 03-06-2011 | 11:44 AM
Check with Dean nickerson
joev01 is offline
Old 03-06-2011 | 07:39 PM
saw that pulley but it looks thicker than a steel one in the center where the balancer bolt goes, hopefully i can get this fixed soon
Old 03-07-2011 | 06:31 AM
Payton's Avatar
Charter Member #927
Maybe this would do it. It's in the Blower Shop section.
http://www.cpperformance.com/p-11395...y-adaptor.aspx
Payton is offline
