Big M Dart block..is it ok for marine use?? >
Old 03-17-2011 | 05:49 PM
Default Big M Dart block..is it ok for marine use??
Does anyone know if a Big M Dart Block would be ok to use for a marine application?
tsayvan is offline
Old 03-17-2011 | 05:53 PM
As long as you machine with the proper clearances, I wouldn't see why not.
Sledge Hammer is offline
Old 03-17-2011 | 06:48 PM
GPM
Might be one of the best for the application.
GPM is offline
Old 03-17-2011 | 07:23 PM
eccsept a merlin TD !
DareDevil is offline
Old 03-17-2011 | 09:27 PM
I was told by a few people that Marine block and street blocks were different. That a street block does not have as much water porting as a marine block. I can get a decent deal on a Big M Daert block rebuild. Cost me about 4800.00 for whole rebuild. Ive got a cracked block with 150 hours on engine and mechanic would rebuild mine with a Dart block. Its a 502 Mag. Does that sound like a decent price?
tsayvan is offline
Old 03-17-2011 | 10:10 PM
only problem is that a 502 mag is a gen 5/6 block and the dart is a gen 4, so your rotating assembly will not work in the dart block. At least your crank wont work.
tx911 is offline
Old 03-17-2011 | 10:11 PM
Is that estimate the cost of the block, machine work, setup, all gastkets and everything needed to put it back together? If so, that is a pretty good price. Except that you are a GenV/VI and the Big M is a Gen IV. So new parts are necessary.
Big M blocks are one of the best for big block builds. I have no knowledge of a difference between street and marine, but I guess there could be.
Beat me to it.....
Philm is offline
Old 03-17-2011 | 10:13 PM
If you are just planning on rebuilding back to 502 mag specs, then the dart block is kind of overkill anyway.
tx911 is offline
Old 03-17-2011 | 11:53 PM
well, maybe you can see it ..but in the classifieds here are plenty 502.ss for a few dollars more , this one is a complete engine ..beefed up and ready to drop in !!!!!
http://www.offshoreonly.com/classifi...o38059-en.html
Old 03-18-2011 | 06:06 AM
it would be a great upgrade over std block
ezstriper is offline
