Sony Subwoofer Installation >
Old 04-16-2011 | 12:16 AM
J-Bonz's Avatar
Originally Posted by US1 Fountain
Step one.
But who reads directions?
Funny you should say that... I actually for once did.... All it gives are precautions.... the only thing that gives any type of directions is...
-Make a woofer box, using wooden boards at least 3/4" thick
Other than that is just a picture I scanned in below..... Thats it....
Attached Thumbnails Sony Subwoofer Installation-scan0001.jpg   Sony Subwoofer Installation-img_1828.jpg   Sony Subwoofer Installation-img_1829.jpg
J-Bonz is offline
Old 04-16-2011 | 01:02 AM
The install in the pics shows a free air install, not a sealed box. It also shows they are suitable for a free air install on crutchfield.
http://www.crutchfield.com/p_158L100...5M.html?tp=972
Griff is offline
Old 04-16-2011 | 02:07 AM
Most marine subs are marketed as free air, but will sound horrible if done that way. Any box even if too smalll is better. Put some pillow stuffing in it and that will fake it out. Trust me on this I use to design this stuff. The sub needs an encloser so that it can create pressure behind it or it will flutter and "free air". You will end up making your amps work real hard for very little sound. This will drain your batts pretty quick.
GTOFFSHORE is offline
Old 04-17-2011 | 03:27 AM
J-Bonz's Avatar
Thanks for the input. That some how makes some logical sense to me... Whats the rule of thumb for how big the box needs to be? I assume it must be in a volumetric units....
Jr.
J-Bonz is offline
Old 04-25-2011 | 01:20 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I'm installing a JL free air sub in my boat. Was going to go free air install, but I have a FG enclosed storage compartment I/m going to use. Remove the door and frame and install a flat acrylic panel in place to mount the sub. I think the volume is roughly 1 1/2-2 cubic feet. Didn't do an exact measurement, just guesstimated.
What does the pillow stuffing do and do you pack it full or just line the walls? Or is that only to do with mounting free air style?
US1 Fountain is offline
Old 04-26-2011 | 12:35 AM
If you have that much room make sure you go no larger and a cube and a half. Less than a cube of air the stuffing works great. It actually tricks the speaker into acting like there is greater airspace in the box by absorbing some of the pressure like a bigger box would do. It works great in tight spots but if you have enough space it works against you.
Those Sony's will sound like azz without a box. You will barely know they are there.
Old 04-26-2011 | 05:53 AM
I agree, however I have had sucess with free air set ups....just have to have the right boat.
The big thing with free air is to make sure the air from the back of the woofer can not meet the air from the front, they will cancel each other out. More work than most people think.
A box always works better. And if you do have the room ported bass works much better in the open air of a boat, band pass even better.
4bus is offline
Old 04-26-2011 | 12:39 PM
J-Bonz's Avatar
Thanks for the input guys!
J-Bonz is offline
Old 04-30-2011 | 10:30 AM
J-Bonz's Avatar
Can I glass a box together using 1/2" marine ply instead of 3/4"... I only have 1/2" and hate to buy more....
Jr.
J-Bonz is offline
Old 04-30-2011 | 10:40 AM
maybe if you galss the whole thing in but would be cheaper and easier to just get more mfd. Plywood is not really that good for sub boxes. Not really dense enough. MFD is the way to go and you can spray it with truck bde liner in a can to somewhat weather proof it.
