500 EFI alignment >
500 EFI alignment
500 EFI alignment
Old 03-27-2011 | 04:34 PM
Wink 500 EFI alignment
I was looking at mt 500 efi's today and trying to figure out where to adjust them to get the alignment straight. The mount appears to be a solid mount with no adjustment? There is an aluminum plate bolted to the stringers theN 3 bolts going through it and the motor mount cradle.
Ther has to be a place to adjust this. Where would it be?
The boat is an 01 353.
soonenough is offline
Old 03-27-2011 | 05:14 PM
STRAIGHTPRIORITY's Avatar
my boat is the same way.... i just pit motors back in today and asked the same question...
i was told that they really cant be adjusted unless u put new mounts... so just hope the factory did it correctly.
luckily mine lined up good and the al tool went in easily.
if it doesn't go in easy and u still get the drive on i believe it will eat up coupler teeth.
STRAIGHTPRIORITY is offline
Old 03-27-2011 | 05:15 PM
they should have been aligned when they were installed. solid mounts like that require the engine be aligned and then the mounts drilled. unless the stringer is rotted there should be no need to move them. what makes you think they need realigned?
compedgemarine is offline
Old 03-27-2011 | 05:20 PM
I just did some more research it appears they are the offshore mounts. I was going to get an alignment tool and check it but was confused as how to adjust it. That would suck having to get new mounts!
Old 03-28-2011 | 09:49 AM
If for some reason the alignment is off, though it should never move once set with offshore mounts, you can adjust the front end of the engine by opening up the mount's bolt holes, moving the entire mount up/down, then retightening when aligned. After you do this, drill another smaller hole on both sides of the mount through the stringer or piece of angle that secures the mount to the boat and through bolt it. This will act as a pin adn keep the mount from moving out of adjustment on the widened holes.
But if your front alignement is moving with offshore mounts, you may have an underlying issue that needs to be looked into.
Philm is offline
Old 03-28-2011 | 09:52 AM
obnoxus's Avatar
Charter Member #1171
Check your rear mounts and how they are installed.
Thats where the problem usually is with offshore mounts,,,,unless like said above you have stringer issues or something else changed
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
