nose cone epoxy >
nose cone epoxy
nose cone epoxy
Old 06-14-2011 | 01:58 PM
Make sure you block sand the epoxy, it's harder than the cast aluminum. I used the epoxy to fill in the nose cone to lower unit, I had to use a belt sander to get it close, it was like sanding steel.
ThisIsLivin is offline
Old 06-14-2011 | 02:36 PM
Originally Posted by rssteiny
How well does the low water pick up slots line up do you need to do some modifing on that as well and where do i get the epoxy.
Also about how long does it take per drive to do this.
Some nose cones come with the epoxy. I know hydromotives do. Should be able to do them both in a 2-3 days with drying-sanding-painting.
picklenjim is offline
Old 06-20-2011 | 01:48 PM
My drive have slots in them for low water pick up how does the nose cones work with that do i need to cut slots to match or what.
rssteiny is offline
Old 06-20-2011 | 03:55 PM
Originally Posted by blue thunder
Here's where I got mine to reinstall my bobs nosecone. Works great and packaged as enough for one nosecone. It was around $25.
http://bobsmachine.com/
That website sucks
How thick can you put on the Sea Goin Poxy Putty? And how well does it apply/smooth out with a typical applicator?
wjb21ndtown is offline
