Clicking,tapping noise after shutdown
Something on the exhaust system / header, close to the head, getting hot with only a little or restricted flow of coolant/water flow across the hot part, and when shut down, the water gets into the localized heat issue area, and cools the area down?
What lifters are you using? Which rockers? This will determine how much preload should be on the lifters when you set the valves.
Could there be any way the pushrods are rubbing on the head and that is the noise when the lifters bleed down? Did you check pushrod clearance in the head?
Eddie
Eddie
The new heads 781's were machined to fit my old SS valves. I don't remember the sizes but it was bigger than stock..The springs were checked, dual spring with damper
new oil seals and they said they set the closed height of the valve springs to specs ?..Cam is 560 lift..236 dur @ .50 and 114 LBA.
Thinking back..When i turned the engine manually to adjust the rockers i did notice a click sound...not positive though
I'm going to pull the plugs and remove the rockers today
turn it over by hand and see if it makes any kind of noises
Check pushrod clearance through the cylinder head, check the contact point of the rocker arm on the valve tip, have you verified the pushrod length is correct.
Last edited by Boat1; 04-17-2011 at 09:43 AM. Reason: Question answered previously.
This is what I am leaning towards, but still a guess. Notice how it goes from a fast tick and slows down. Similar to when you pull the car into the garage and shut it down and the exhaust may tick for a few seconds. That's what it sounds like to me. Does it do it when the boat is in the water with possibly better flow into the engines?
I am interested in the comp cams steel rocker with the roller tip..also new pushrods.. I do not want to change the height of the rockers due to the ease of removing the valve covers without removing the exhaust.
