Belts for HP 500?
Yes, using the engine serial number is the best way to find the correct Mercruiser part numbers for your engine or drive system.
Also just as a FYI the serial number you posted is missing one number at the end, There should be a "0L" then there should be six numbers after it to find your engine, especially with your engine because it would mean the difference between having a Carbed engine or a EFI engine if your off one number.
From what I can tell from the serial number you posted and me guessing a final number, Your engine does not have Power steering?
Merc part number 816034 is Superseded to 816034Q $42.78 Description: V BELT, 48.125 LG (Water Pump)
Merc part number 812427T is Superseded to 812427Q, MSRP: $47.90 Description: V BELT, 56 LGTH (If you have "Power Steering")
Merc part number 69143T is Superseded to 69143Q MSRP: $27.30 Description: V BELT, 40 LGTH (Sea Water Pump).
And here is a link to all of your engine parts for you.
http://www.mercruiserparts.com/selec...doc_nbr=878389
Hope this helps, Good luck.
I am not finding them though on the link very easily.... but will keep looking. I'm not seeing the alternator belt though, but maybe I'm picturing this wrong and it's w/ one of the 3 listed.I pulled that off the survey, wonder why it didn't have all the digits.
Looks like the $100 or so for the merc parts from the marina may not be too bad but now I can shop it around.....
