502/450 hp gm blocks whats the mystery ?
Ok somebody explain to me what the difference between a 502/450 HO gm crate motor and a 502/450 gm crate marine motor other than the slight cam difference,brass freeze plugs,and a 8.1 oil pan versus the 6.0 on the HO. If you look at the specs in the gm performance catalog they are nearly identical. They HO even has the composite head gaskets w/stainless fire rings and brass freeze plugs . I'm more less talking the rotating assemblies and blocks. The consensus I'm getting is like 50/50 some say they are built with different tolerences and some say no difference. Somebody fill me in please. This seems to be a huge mystery in the marine world.
1st off GM does NOT assemble the marine engines, they are sub contracted out, and are sold with NO GM warranty, that is left up to the marine division that ultimatly sells the unit, they sell the automotive with a 3 year or so warranty thru GM dealers as long as you supply a vin thats usable. the engines them self are not that much different, camshaft, head gaskets, valves in most cases...
The same short block gets used for all the GM performance crate engines and marine. The short block is a good deal and with a set of AFR's and a good cam (Bob M) 650-700hp is no problem.
I have verified with Mercury Racing that only the blue motors are rebuilt by Merc - the black motors simply have whatever parts GM puts in them. Regular Eaton valves are used, probably not inconel, although Eaton does make an inconel valve, and I have seen it documented that GM started using inconel exhaust valves in some of their later model medium duty truck engines due to valve recession in severe duty applications. It is unclear if that was extended over to the marine engines.
Now there the answers I'm looking for. I was told by a good friend to buy a short block zz502 put a set of decent heads and he said the cam that comes in the block is identical to the HP500 cam,He suggested a set of heads from arrowhead a perfomer intake and a holley 800 and it should be real close to 500hp Now he also said the 6 quart oil pan was more than suffient for how I was going to use the boat, I don't know if I necessarily agree with that. I'm on a real tight budget for this project and we priced it out and I can build both of these motors for a hair above 15 grand
sorry but you guys are wrong..I had a issue with a new GM marine engine..talked to several people within GM with help from my local chevy dealer...ended up talking to a very good guy at GM powertrain..he told me in fact they do NOT assemble any marine engines themselves, they have a subcontractor shop that assembles ALL the complete engine and they are sold with NO warranty thru GM, was also told tghe same thing from crusader, the warrenty is up to whoever marinizes them is the warranty holder..if you do not believe me contact GM powertain, or a dealer and try to get warranty on a "marine" engine
