Stereo issue with amp
#36
good to hear.
Most people don't understand wire length is the major issue with DC power. Go big or go home.
#37
#38
I would pull big wire for power and ground you can use a block and step it down to what ever size you need right before the amp that way if you ever want to run more amps you have the hard work already done, if there is any chance you will run more than one amp I would pull 0g wire then drop it down to 8 or 4 right before the amp
#39
Both wires same AWG.
