Anyone using Cheap Ebay HEI distrubutors >
Old 05-31-2011 | 01:12 PM
Default Anyone using Cheap Ebay HEI distrubutors
I'm curious if anyone is using the cheap $40 HEI distributors that are on ebay? I'm sick and tried of trying to track down the issues I'm having with my thunderbolt ignition!
endeavour32 is offline
Old 05-31-2011 | 02:50 PM
Rookie's Avatar
I know of about 10 of them being used right now. The 65,000 volt. Make sure you drill a hole in the bottom to let heavy vapors out and put some steel screen material to cover the hole. Marinize them.
What troubles are you having with the TB's?
Rookie is offline
Old 05-31-2011 | 03:17 PM
i'm no expert on the law because they don't have any down here but doesn't the CG require some sort of mystical certification on that stuff and you get your dick stomped if they inspect and it isn't right ?
stevesxm is offline
Old 05-31-2011 | 03:39 PM
I wouldnt put a $40 main ignition component on ANYTHING I own...let alone something that could leave me stranded, possibly in bad weather, possibly with others on board, and with no way to walk back !!!!
tinman565 is offline
Old 05-31-2011 | 03:48 PM
to be honest about that you would have to acknowledge that that dist probably has exactly the same chinese amp in it that the expensive ones do... just without the brand name. the chinese supply the vast majority of all those sub assemblies these days to every major manufacturer
stevesxm is offline
Old 05-31-2011 | 04:47 PM
Getrdunn and I thought Rookie was running them without issues.. However I found the mysterious issue I was having. After three people including me pulled our hair out trying to figure out why I was not getting any spark. I completely disconnected the tether switches from the ignition and the engines instantly fired up and ran great! So no need to change anything now!
Old 05-31-2011 | 04:59 PM
Sweeeet !!! Glad you figured it out.
Old 05-31-2011 | 05:08 PM
So am I, it was driving me nuts along with everyone that was helping me.
Old 05-31-2011 | 07:33 PM
articfriends's Avatar
I bought one from KMJ for a customers street car, haven't heard anything back from him at all, it was like 49$ for a complete gm hei, coil, cap, module, everything, turn key, Smitty
articfriends is offline
Old 05-31-2011 | 08:38 PM
If the car broke down....he could get out and walk right ?
