-   -   Whippled 500 EFI Injector help! (https://www.offshoreonly.com/forums/general-q/256811-whippled-500-efi-injector-help.html)
DRP 06-28-2011 12:26 PM
I have a Whippled 500 EFI that has a bad fuel injector...does anyone know what pound injector is in there or where I can get a matching replacement? I had them cleaned and bench tested by a diesel injector company and was informed that the one was bad, so I told them just to match one up and they told me they can only buy diesel injectors??? I did not know when dropping them off that an injector company could only buy diesel. Sounds weird to me but that's where I am at and could use some help or suggestions. Thanks in advance!
wannabe 06-28-2011 12:41 PM
The injector should say on the side what # it is. Or there should be a part number.
Wannabe
DRP 06-28-2011 01:05 PM
Wannabe
I can check the injector when I get home but I am almost positive that it only has a part number, it does not say what pound it is.
Greenkeeper 06-28-2011 01:21 PM
mine are 65lbs. 3.3 ltr.
Call Whipple
Trash 06-28-2011 01:36 PM
Many times injectors don't have a part number on them, which can be problematic. I had my injectors cleaned and flowed at WitchHunter Performance. They did a before and after flow/spray pattern analysis. That should tell you what the flow rate for the injector is. Prior to that I knew nothing about the injector other than the brand (Keihin).
Is the injector spray and flow bad? I had one that flowed poorly and had a poor spray pattern. They were able to clean it and get it working correctly again.
DRP 06-28-2011 02:17 PM
They told me before even cleaning it but after bench testing that it was not good.
Ideally, I would just like to get one to match the set I have and then get a new set for next year...I just don't know anyone that can do it.
DRP 06-28-2011 02:24 PM
Looking back at the paperwork, it says they are all within 10% of each other except the bad one.
The number that is on the ones I have are: 6192 17104487
Thanks again for everyone's help!
JasonSmith 06-28-2011 03:31 PM
Is it the Merc injector or the Whipple one?
I think the Merc ones are 38lb/hr injectors.
DRP 06-28-2011 04:51 PM
I'm not sure which they are, I bought it with everything as is. I would post a pic, if it would help, but I'm not sure how to post one. The only other identifiers I have is the number on it.
JasonSmith 06-28-2011 06:23 PM
Where did it come from?
