Engine Remote Starter Switch >
Old 07-07-2011 | 09:50 PM
Default Engine Remote Starter Switch
Anyone used a remote stater switch on a boat engine? Seems that it would be helpful when working on the engine alone?
TEXASRPM is offline
Old 07-07-2011 | 11:04 PM
I have done them before. They are very handy. Just a little advice....put a seperate switch to activate the push button so it doesn't get accidentaly hit either when the engine is already running or when it's off and someone's hands could be in there.
I actually did one with a small panel that was mounted off to the side of the engine compartment. It had a key switch (just on and off) and the starter push button. You can either make it where it will just spin the engine over or you can set it up to actually start it. Let me know if I can help.
Eddie
Young Performance is offline
Old 07-08-2011 | 07:49 AM
See your local tool truck,sears etc. They have a switch with alligator clips that will keep you from having to hard wire it.
SHAWN DAVIS is offline
Old 07-08-2011 | 07:56 AM
Dean Ferry's Avatar
Yep,
I have 1, it works great when working in the engine compartment by ourself.
Dean
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 07-08-2011 | 08:36 AM
Originally Posted by Dean Ferry
Yep,
Dean
+1
BenPerfected is offline
Old 07-08-2011 | 09:16 AM
If you want a permanent switch, check out the Painless Starter Switch (about $20). It is waterproof with a rubber cup cover. We mounted ours on the vertical ignition plate on the port side of the engine so it is a short jump to the rear mount starter switch. Very clean and handy when adjusting the valves.
Old 07-08-2011 | 10:49 AM
Eddie
do it this way. eddie is exactly correct. the aligator clip idea sounds great until you are laying in the bilge trying to fumble them on and short across something. do it one time. do it correctly
stevesxm is offline
